Fusion forcing me to move my projects to a shared team hub
qb8Zk3uwM8BlyTpd
qb8Zk3uwM8BlyTpd
Fusion 360 is now forcing me to move all my personal projects to a "hub," but the only hub option it's showing me is a team hub I created for collaboration and is shared with other people. I can't seem to create another hub (in fact I can no longer access any of my data anymore since this popup is all I see), so how can I keep my projects in an area where only I can access them? It seems the only option is to move them all to a shared hub that already has other stuff in it.
I still haven't migrated to hubs because of this issue, plus the fact that interacting with the dialog before would give some unspecified error and tell me to try again later.
If you're going to force people to move their single-user storage to a hub, why can't we have the option to just make a new hub with the same contents?
RajkumarIlanchelian
@qb8Zk3uwM8BlyTpd If you already have a hub, you should be able to move your projects there and have full control on what projects others in your hub sees or doe not see. It can be done to the folder level.
@Andy.Spivey @porkodi_autodesk Andy, Porkodi anything else to add here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
rajat_mehtaL58QJ
Hi @qb8Zk3uwM8BlyTpd ,
Can you share the email id associated with your hub in private message with me ?
I will investigate and update here .
Rajat
