file problem
file problem
jyounglim
file problem
jyounglim
Problem 1. I upgraded the file from version 2022 to version 2026. Even though I saved it as version 2026, the upgrade process is performed every time I open the file.
Problem 2. When I run Dynamo on the upgraded file, the file is forcibly terminated due to an error.
Thank you!!
RajkumarIlanchelian
@jyounglim
"the upgrade process is performed every time I open the file."
Can you please expand on that some more? What is the upgrade process that you are seeing?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
jyounglim
This upgrade means upgrading the file from version 2022 to version 2026.
RajkumarIlanchelian
@jyounglim Are you implying that the file is not being saved in the newer version? Is it possible to record a small video of what you are doing and seeing?
Autodesk Fusion
Join Fusion Insider
