Create projects form folder
rozicuros1
rozicuros1
Hi there,
I have quite a strange situation with my project structure:
Until a little while ago I was not aware that you are able to create multiple projects in Fusion 360 (since I worked as single-user storage). So instead of creating multiple projects, I created multiple folders in only one project. This seems to be a good way around at the time.
Now I found out that if I create the team I am a member of, I can create multiple projects. This makes things a lot more organized.
Now the problem I have is that I cannot find a way to move my old folders (which served as a way around for projects) in single-user platform to a team platform and create a project from each one.
Many thanks for help.
Uroš
sasikanth.kollipara
Thanks for using Fusion
The above job can be achieved in a 2 step process.
1. Transfer the project from Single user storage to Team.  (link on how to transfer is here).
2. Once you confirm all the folders are in the Team, then use Move functionality to newly created Projects.
Let us know how it works.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
Sasikanth Kollipara
Product owner and customer support in Fusion
LinkedIn
rozicuros1
Thank you @sasikanth.kollipara for the quck and clear reply.
I have tried to follow your procedure and there seem to have been some issue with transferring the projects to teams.
The server has been loading the project from a single user for more than 30 min. I do have quite a bit of folders so maybe it just needs more time to get through all the folders.
I will keep you posted.
BEst regards,
Uroš
rozicuros1
Hi @sasikanth.kollipara, it has been one hour, and the "Projects to move" tab is still loading.
Any sugestions?
sasikanth.kollipara
Sorry for the inconvenience caused.
Can you try to do the same from here, from the Fusion team web interface of transfer.
Go to single-user storage from team switcher, by clicking on the profile icon.
Sasi
Sasikanth Kollipara
LinkedIn
rozicuros1
Many thanks! That worked 100%.
Many thanks!
