Component View - New View in Fusion Team!
britta.ritter-armourP22BT
Alumni Alumni
As you might have seen in the November 2021 What’s New, you can now view assembly structure, external and internal components, and granular information about a design outside Fusion 360 via Component View, available as a tech preview in Fusion Team.
Learn more about Component View on the Fusion 360 blog.  Once you've tested it out, submit feedback on the Feedback Forum
We look forward to discussing!
ImDaveM
COmponent view is TERRIBLE!
Just give us a BOM VIEW instead!
Component view shows all the messy stuff, try looking at a PCB, there are things in there that should not appear, like copper holes, silk screens, layers etc and other silly stuff.
It should just show the ACTUAL ITEMS , such s PCB Board and components.
It should IGNORE components that were set up as FOLDERS so we could group items together.
I really don't see what advantage COMPONENT VIEW will bring?
We still have to sift through all the data folders.
The icons of the components are too small!
The navigation names of folders projects etc across the top get TRUNCATED even though there is plenty of room to display the full names.
The component view is really no different to the browser tree, except for a few more fields ( that you cannot edit anyhow)
I also tried out the FUSION Mange Extension, its basically the same thing, and again, show all the rubbish data!
So I cancelled my subscription for the extension!.
Instead of component view, how about give us a drop down menu where the browser tree header is and we can select our own custom views!
regards
Dave M
ilugo628
Observer
Observer
hola
Hace unos dias instale Fusion 360 y he estado trabajando bien, pero ahora intento abrirlo y no abre; no sube la imagen. Tengo windows 11 dsde siempre
tookemtoni
Just give us a flat view BOM. Please.
