Cannot upload csv file of class list using the automated "create classroom and invite students" process
carrescian
carrescian
When I attempt to upload the csv containing my class list, I am receiving the following error:
"Error uploading the file. Please try again."
This process worked seamlessly prior to today. I am using the standard csv template as instructed.
https://hdsb218.autodesk360.com/g/teampicker?mktvar002=5038656076%7CEML%7C530869891&utm_medium=email...
HAWCadLabor
I have the same issue this year and depend on that process. Otherwise I will have to invite >100 students and setup all the directorys and access rules manually. 😟
Is there any information about the status of this? Was it only a test?
carrescian
@HAWCadLabor No, it was not a test, I was trying to help a colleague setup his class, but ended up entering students manually into the project folders. This is an odd problem because the automated process last worked for me on January 31st. I'm not sure if there is a bug that needs to be addressed in a future update??? I have yet to test it again, has anyone been successful as of late?
HAWCadLabor
It seems that i found the right person to declare this issue.
Actually the process works again 😀 and today i  was able to set up a 84 students-classroom in 15 Minutes.
 There is still an issue on project level where you have to delete the access rights which have to be set on the ressources directory manually. But that will be fixed as well soon.
In germany you need to replace all the semicolons with colons before uploading and i prefer swapping surname and lastname because of the order of the directorys in the classroom.
carrescian
I can confirm that this issue has been addressed and is now working.
