Assembly file composed of linked components is now empty - reduced to V1
TJS01
TJS01
EDIT - CRISIS AVERTED.  Another colleague had a backed up version from a couple years ago.
14 hours ago I had a file open - an assembly made up of mostly linked files.  This has remained unchanged since 11/2022.  I had it open to stage some screen shots for colleagues.  I did not save changes (intentionally).  I don't believe I closed fusion, and maybe not even the file when putting the laptop (PC) to "Sleep".
This morning I went to open that file on another machine and it is 100% empty and shows V1 and a date of 11/16/2022 (the last time I actually saved any changes).
I searched around for solutions and saw the F cache folder may contain a .F3D of what I have lost, but apparently, only the individual files appear there. - EDIT - after leaving the empty file open for a bit, I did see that populate in the F folder, however, the instance from last nights session does not exist - only files that make up the assembly.
Is there any hope of recovering this or am I faced with completely rebuilding?
dsouzasujay
Hi @TJS01 ,
Can you please visit the online version of Fusion at fusion.online.autodesk.com and sign into your account and see if you can see the files?
How to access Fusion using online version
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
