I have a drawing that looks fine in AutoCAD. However, in the Fusion Team viewer there are lots of annotations missing and not displaying properly.
Please see my 2 attachments....you can see how it should look, and what it actually looks like in the Fusion viewer. How can this be fixed?
hi Bonn,
I believe the file was created in Autocad LT. I viewed in Vanilla Autocad.
I will send you a link to the project.
Hi Bonn,
I'm having the team look into this further for you.
Stay tuned,
hi Bonn, I'll ping the team again on this to see where they're at.
Is it just the one file or are you seeing the same behavior on other dwgs as well at this point?
is there any difference in the version of AutoCAD they're created in, or if they came from another product initially, or how the dimensions were added?
anything like that perhaps re: why/how they're different than the ones you're uploading and having success with?
Just trying to brainstorm a bit here,
A quick update here Bonn,
The team is still working on this and trying to figure out exactly what is causing the issue.
No ETA on when will be resolved, but i'll keep you up to speed here.
hi Bonn,
Just heard back from the team.
They found that because there are entities that have a thickness value, that is what is generating the 3D view, which really shouldn't be happening since only in 2D
Try the below steps to remove all thickness' from the entities and then resave / reupload. That is what then worked for our team.
Steps in AutoCAD commandline in “Model” tab of DWG:
CHANGE / ALL / Properties / Thickness / 0.0
Have a great weekend 🙂
Hi Bonn,
Can you let me know if all worked out ok for you now on this case?
Please let me know,
I replied last week…it did not work for me. Has your team tried it?
Here is what I did:
Command: CHANGE
Select objects: all
12062 found
2 were not in current space.
Select objects:
Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: t
Specify new thickness <varies>: 0.0
Cannot change thickness for MTEXT.
Cannot change thickness for DIMENSION.
Cannot change thickness for HATCH.
Cannot change thickness for LEADER.
Cannot change thickness for BLOCKs.
Cannot change thickness for SPLINE.
hi Bonn,
I didn't see any reply here in the forum thread or in my private message area here in the forums, so my apology for missing that.
Yes, our internal team tried what i recommended to you which then eliminated the 3D view (which maybe we wrongly assumed shouldn't be there in the first place?)
Let me know if we approached this in the wrong way.
Here is the public link to the final file that they produced (below) as well the steps they took that might provide more clarity for you.
Notes from the team:
I think it is due to some objects having a “THICKNESS” property > 0. So that gives the DWG some “3D” quality and triggers creation of a 3d view.
Can you see if the attached file works more as-expected with just a 2d-view and no 3d view?
I suspect there are still some objects (maybe inside BLOCK inserts) that still have non-zero elevation &/or thickness because when I set the AutoCAD “VPOINT” to being an edge-on view such as 1,1,0 I can zoom-in and see some things still have thickness. But when I uploaded this edited/resaved DWG to LMV it seemed to produce only a 2d view for me.
Here’s what I did:
I used QSELECT to find the culprits… 744 LINEs have various, non-zero THICKNESS.
I had to repeat the operation for the other objects in the DWG as well
e.g. POLYLINEs … 54 had non-zero THICKNESS of 0.544
CIRCLEs … 36 had various non-zero THICKNESS
ARCs … 132 had various non-zero THICKNESS
Bonn, here is some additional info as well for you that i got from our team on this, re; what you saw re: the messages as well the intent of what you're trying to do.
