Fusion Support
Z setting off after lead hung slightly on side of gantry
0 REPLIES 0
Message 1 of 1
lx5_ranch
42 Views, 0 Replies
The torch lead slightly hung the side of the gantry and now the torch tip no longer extends all the way down to touch the metal before retracting and firing. The torch fires then stops once cut sequence begins a couple of seconds later. The torch height is too far away. I have made sure the torch is set where it is supposed to be in the mounts.
How do I reset things?
0 REPLIES 0
