Fusion Support
Z height issues with Haas pre NGC post
0 REPLIES 0
Message 1 of 1
danielbLYSKL
87 Views, 0 Replies
we are running a Haas GR510 gantry router with the standard Haas pre NGC post.
The tool changer height is several inches lower than the max z height of the machine.
After a tool change the tool moves first in x and y before retracting to the save travel height set in fusion,
therefore it will crash into vices, fixtures etc.
O01001
(Using G0 which travels along dogleg path.)
(T5 D=0.2031 CR=0. - ZMIN=-0.16 - flat end mill)
N10 G90 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(2D Contour3)
N30 T5 M6
N35 S900 M3
N40 G55
N45 M8
N50 G0 X-10.3949 Y-1.0287
Is there an easy way to modify the post so it will output a g28 z0. after every toolchange?
Thank you,
Daniel
Tags (3)
Labels (2)
0 REPLIES 0
