Z- Axis View
Z- Axis View
Z- Axis View
Hello, I am trying to enable the view of the z-axis line, but I do not know how to enable it.
Can someone please help me enable showing the blue line?
MoshiurRashid
Thanks for posting. Go to Preference, And go to general and select the "Default modeling orientation" as Z UP.
Now, If that is not the thing you're asking, you might want to see parallel to the Z Axis. For that just go to the View Cube and select TOP.
Please Mark the solution as ACCEPTED SOLUTION if it works for you.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
that was already active, and did not work.
MoshiurRashid
What and why exactly do you want to achieve? Can you tell me with a picture or video reference?
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
HughesTooling
When are you trying to get the Z axis, in a sketch or outside of the sketch environment? The blue Z axis doesn't show like the XY axis, you can make the origin visible or within a sketch if you enable 3d sketch the axis will appear when you select a sketch tool. Below is in a sketch with 3d sketch active and I've selected the line tool.
Mark
Mark Hughes
Owner, Hughes Tooling
