Announcements
Your rendering could not be rendered because an error occurred.
stovri
Message 1 of 11
stovri
I am trying to render my project using the cloud renderer, and it consistently gives me the error message: "Your rendering could not be rendered because an error occurred." I was able to open a previous version and render it from the cloud. I rebuilt the entire project, and tested the rendering at each step, and I could not find where it was failing. However, the new model has recently having the same problem.
Here is the original model:
https://a360.co/48NvOPf
Here is the rebuilt and updated model:
https://a360.co/3V8Z3ZE
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@stovri I can already see that clicking on either of the models that we cannot even generate the preview. So certainly something going on and would be surprised if rendering worked. Taking a look at the design now. In your data panel does the latest version of these files have thumbnails?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
RajkumarIlanchelian
@stovri
Team 7125 - Tigerbotics Nice 🙂
My son is in his high school robotics too!
Autodesk Fusion
Join Fusion Insider
Message 4 of 11
stovri
Yes, the thumbnails are there.
Message 5 of 11
RajkumarIlanchelian
@stovri Have been investigating the "original" file. So far it seems like motor beam and bottom beam are contributing to the issue. If you open them in Fusion team and try to generate viewables they cannot be generated. once I eliminate these two (delete ) from "Frame Legs" and then save all the upward assemblies, I can start generating viewable which means rendering also will work.
I need to figure out what is special in Motor beam and bottom beam.
Autodesk Fusion
Join Fusion Insider
Message 6 of 11
RajkumarIlanchelian
@stovri Try to generate rendering for Frame legs and it will fail. This is the root assembly where the failure is starting. Bottom beam and motor beam by themselves are ok in generating render but when they come together in Frame legs there seems to be som issue. Still investigating.
Autodesk Fusion
Join Fusion Insider
Message 7 of 11
stovri
Motor Beam and Bottom Beam are part of the Maslow M2 CNC machine. I had made a model of it to help visualize the placement of the Intake Sidewall while it was being cut. I can just remove it and it would not have an appreciable effect on the model. It is surprising that the model of the CNC machine would have any effect on the rendering of the robot.
Message 8 of 11
RajkumarIlanchelian
@stovri Maslow M2 is where I was heading towards and the one in the manufacturing environment. Once you remove it and save I think everything else should go through fine.
It just may be a defect on our side on how we generate viewable that may be causing this limitation.
Autodesk Fusion
Join Fusion Insider
Message 9 of 11
stovri
I deleted the CNC machine and remade it without the CAD model for it. The rendering works now! Thank you so much for your prompt response!
Message 10 of 11
stovri
Best of luck to your son's team!
Message 11 of 11
RajkumarIlanchelian
Thank you!
Autodesk Fusion
Join Fusion Insider
