Announcements
Yellow Sketch - Cache Geometry to solve
boostwanga80
boostwanga80
I'm new to the forum and the software. I've drew this sketch onto this body (Side Sketch #2), and then I went back to make a change to the body, and now it shows this "Cached Geometry to solve. Please reselect Reference Geometry for failed feature in the time line"
If I go back into edit sketch, I don't see any yellow lines, nor can I find the "Manage lost projections" under right clicking of the sketch profile.
I'm speculating this is the reason why people like to draw on offset planes rather than the body itself in case you need to come back to make changes to another part of the body, from what I've gathered so far.
The highlighted red section was the previous sweep body. I've since then sketched up another pathway on the same sketch, and re selected that new profile and sweep path as well. The side sketch isn't recognizing the new body for some reason, and I can't find a way to make it recognize it.
I'm wondering what are my options at this point, and since I've searched for hours, I think I could share this and use some help while I ponder around what else could be done at this point.
HughesTooling
Are you right clicking the sketch icon in the timeline when you try to activate "Manage lost projections"?
Mark Hughes
Owner, Hughes Tooling
boostwanga80
Yes,
Tried on the timeline, and the list of sketches on the left side column.
jhackney1972
Attach your model so the Forum users can help you out.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
