Announcements
'x-ray' mode accidentally turned on
mumbynicholas
Observer Observer
mumbynicholas
Observer
Observer
Somehow I've enabled a completely transparent 'x-ray' like mode. I've tried adjusting the body appearance, material and opacity with no success.
How do I turn it off?
HughesTooling
2 thoughts, check your visual style and also check the physical material. Can you share a file with the problem, export as an f3d and attach.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
mumbynicholas
Observer
Observer
Perfect thanks. I must have pressed Ctrl+8.
ronwebjr2
What did you do to fix this issue? There is not an answer provided in the support page you started.
Just click shaded or shaded with wireframe 🙂 (Edit) Sorry, shaded with visible edges
