Wrong profile extruded, simple profiles with spline intersect
camdotcam
camdotcam
I've been experiencing a ?bug? where I'll select one profile to extrude, and the preview showed the expected result, but when I complete the extrusion I instead get a completely different result.
Editing the extrusion from the timeline shows me that the wrong profile is now selected for that extrusion.
I only see this behaviour when I'm working with sketch profiles of shapes that are intersected by a spline.
I think I can reliably resolve it by trimming, or by using the offset tool to make a similar shape.
How can I avoid this without workarounds?
.F3D file and screen recording attached
camdotcam
My workaround is to create a new sketch and then project the original sketch to it, as shown in the attached video.
It seems that if I do any other extrusion, or select more than one profile to extrude it will also work as expected.  This seems to me like a bug.  The video shows the behaviour described
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@camdotcam
As long as the spline profile is closed, this issue persists. Two ways to resolve this:
  1. Break the spline profile at one of the circles.                                   sanjanashankargoli_0-1640082495938.png
  2. Select two profiles includin the unwanted profile and extrude cut the unwanted portion subsequently sanjanashankargoli_1-1640082722841.png
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
camdotcam
Thanks, I've been doing similarly and it's working
