Fusion Support
Wrap a seemless wavey pattern around an object
4 REPLIES 4
billyamann
231 Views, 4 Replies
Hi there,
I have searched high and low for any kind of way to do this. I've only been a user of Fusion for around 4 months, so still fairly green. I have in mind a shape with an uneven, yet seemless wavey pattern wrapped around its sides.
So here is an idea of the form?
And here is an idea of the kind of wavey pattern.
The problem is the tutorials I am finding for this is for flat panels. Such as https://www.youtube.com/watch?v=ltqmIIbAoVE&t=59s . A commenter asked how they would wrap this around a cylinder, but the answer was: No idea.
I don't see the seemless part to be the issue, as I am sure I could figure that out. It's more the creation of the uneven waves and wrapping them.
Any advice would be greatly appreciated.
Cheers
Billy
Here is my workflow for averaging splines and making some artsy stuff from that :) If you get stuck ask for help in the comments :)
4 REPLIES 4
TrippyLighting
in reply to: billyamann
Wrapping it around a cylinder is almost trivial and has been demonstrated many times.
The trick is how to make it seamless. Do you have a seamless design for wrapping?
You can even wrap things around spherical objects, albeit that is not trivial anymore 😉
billyamann
in reply to: TrippyLighting
Thanks for your reply. Do you mind throwing me a bone to one of the many demostrations please? I am struggling to see something that fits what I need.
There are tonnes of demostrations on how to create a seemless pattern. I am more versed in that regard than putting it onto an object. So thats not really my biggest concern.
TrippyLighting
The idea is to use the sheet metal tools.
In this thread, I wrap a wavy panel around a filleted corner.
Different geometry, but the same principle.
If that bone is too skinny, please create your desired 3D seamless pattern, and we'll work from there.
billyamann
Thanks, this is the exact answer that I was looking for. It's not an element of Fusion that I've encountered, so was obviously looking in the wrong places.
I now know which direction to head.
Cheers again.
Technology Administrators
