Fusion Support
WOW! Difficulty: Mate Plug in Tube
3 REPLIES 3
gordiehl
92 Views, 3 Replies
Hello again!
WOW!  There has to be a way to do this simple little move/mate to face/point/line or something!
I'm just trying to move a "plug" body into a 1.125 x .120 wall tube.
It should be self-explanatory when you look at the drawing.
Any guidance would be much appreciated!
I have attached the simplest test drawing I could.
I hope to hear.
Thanks!
G
3 REPLIES 3
jhackney1972
in reply to: gordiehl
To use a Joint, the tube has to be changed into a Component, which I did.  The Plug has been added as a Base Feature, not parametric, but it will function as a component for a Rigid Joint.  Model is attached.
Edit:  I have attached a revised model.  I converted the plug, the Base Feature body into a component so now both are component.  It is best to use Joints to assembly components instead of trying to Move Bodies into position.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
gordiehl
Ahhh!  A feature/function I have not worked with, yet.  I'll take a look.
Thank ya Sir!
gordiehl
LOL! Incredibly easy! I think I was stuck on.. 'I'm doing something wrong'. A quick web search of 'Fusion join parts' only returns about 10K videos LOL. Thanks John!
