Wont connect to the internet - Please HELP ME
piettro_laurindo
Message 1 of 12
piettro_laurindo
I'm unable to connect to the internet through Fusion 360, I'm going crazy here, I've tried EVERYTHING! I have educational access, my system is Windows 11, a Dell Ryzen 5 RTX 3050. Everything was fine until yesterday, suddenly went offline. I've tried:
  • Repairing and reinstalling, and I couldn't even work offline anymore
  • Formatting my computer and reinstalling, also didn't work. now i cant even instal fusion
  • Unchecking the read-only option, but it keeps reverting, showing just a dash symbol (image1)
  • Trying to create permissions in proxy, but I'm not sure if I'm doing it right and i dont use one.
PLEASE help me, I really need it for my college work.
Replies (11)
Message 2 of 12
RajkumarIlanchelian
@piettro_laurindo @Can you please try a couple of things ?
1. Can you connect to a different network like your mobile hotspot and see if Fusion launches in online mode?
2. Can you restart your router and see if that helps ?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
piettro_laurindo
Its works!!!!! UAU jesus im felling dum, all day long and thats the solution, switch to my internet phone and it works. But how can i fix my wifi?
Message 4 of 12
RajkumarIlanchelian
@piettro_laurindo @So something in your current network is blocking access. Did you try a restart of your router ?
Autodesk Fusion
Join Fusion Insider
Message 5 of 12
piettro_laurindo
Yes, so many times heheh but dindt work
I dont know how to solve it, but i guess is something with this:
https://ui-dls360.autodesk.com
Run the diagnostics, and the results are in the image bellow
Message 6 of 12
RajkumarIlanchelian
@piettro_laurindo @If you click on the link and open in your browser what results does it show.
Autodesk Fusion
Join Fusion Insider
Message 7 of 12
piettro_laurindo
On my wifi, nothing Image 1
But in my internet phone, apears this: image 2
Message 8 of 12
RajkumarIlanchelian
@piettro_laurindo @The second image is the response you need to get. So in your WiFi it seems like either your firewall or something else is blocking this access. If you go windows defender and turn off your firewall see if you can access that link. If you can then it is the firewall that will need to give it access.
Autodesk Fusion
Join Fusion Insider
Message 9 of 12
piettro_laurindo
First, want to thank you for help me,
disable all firewalls, but not work =/
Message 10 of 12
RajkumarIlanchelian
@piettro_laurindo @If you login to your router you will see it has a firewall too check it there. It might be that the ISP is blocking it? I say that because if you went with a different ISp (your phone) it worked.
Autodesk Fusion
Join Fusion Insider
Message 11 of 12
piettro_laurindo
I dont know how to get my wifi thoght my browser, buuut i menage to solve it follow this commands in the cmd:
netsh winsock reset all (Enter)
netsh int 6to4 reset all  (Enter)
netsh int ipv4 reset all   (Enter)
netsh int ipv6 reset all   (Enter)
netsh int httpstunnel reset all  (Enter)
netsh int isatap reset all  (Enter)
netsh int portproxy reset all  (Enter)
netsh int tcp reset all  (Enter)
netsh int teredo reset all (Enter)
NETSH INT IP RESET all (Enter)
ipconfig /release  (Enter)
Ipconfig /flushdns  (Enter)
But im curious, what is your guest to this problem?
Message 12 of 12
piettro_laurindo
And again, thanks for your support,
Im really appreciated
