WinError 2 Install Issue
Escarpment
Observer Observer
Escarpment
Observer
Observer
When installing Fusion 360 I keep getting a WinError 2
I have gone over the forum and checked and followed the trouble shooting guides. Have also installed in Safe mode, had the Anti-Virus switch off etc, but everything that is suggested on here does not work for me.
I have attached the Log file.
Hoping you can help
jhackney1972
When you executed the Streamer Exe, did you right click on it and select "Run as Administrator"?  I would not try to install in safe mode and I would continue to make sure the Anti-Virus is "disabled" during installation.
John Hackney, Retired
Escarpment
Observer
Observer
Hi, yes did that as well, made no difference, always the same error
dooyoul_chung
Hello @Escarpment
Could you please apply below solution? Hope it works for you.
https://forums.autodesk.com/t5/fusion-360-support/probleme-installation-fusion-problem-installing-fu...
Dooyoul.
Escarpment
Observer
Observer
Thank you for your time, that worked and I am now up and running
