Announcements
WinError 10061
JHRendon
WinError 10061
JHRendon
urlopen error [WinError 10061]
Replies (12)
James.Youmatz
Autodesk Support
Autodesk Support
Hi @JHRendon ,
This is due to you having a proxy server set up that is refusing the connection to our servers from your computer.
2019-07-17 06:52:12,724 - MainProcess(12180) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled True
Are you aware you had a proxy setup? If so - have you whitelisted all the ports and domains? If not, can you disable your proxy and try installing then.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
JHRendon
I don't get it....
where can i see that? I do not know if I have proxy connections...
James.Youmatz
Autodesk Support
Autodesk Support
Hi @JHRendon ,
This would be under the LAN settings which is greyed out because your machine is configured by a system admin. Can you contact them and inquire about the proxy connection?
James Youmatz
JHRendon
What you mean? This is my personal computer? What i need to do?
James.Youmatz
Autodesk Support
Autodesk Support
HI @JHRendon ,
Try this:
  1. Search for command prompt
  2. Run command prompt as admin
  3. type: netsh winhttp show proxy
    1. Does it show a proxy, or does it say direct?
  4. If it shows a proxy, type: netsh winhttp reset proxy
Let me know if that works.
James Youmatz
JHRendon
It says this?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @JHRendon ,
That is strange you are getting that proxy error then. Can you try running a virus scan, as well as launching the Fusion installer as an admin?
If that fails, we can schedule some time to do a remote session.
James Youmatz
JHRendon
Virus scan says all is good... 😞
where we can make that remote session...  i can do it any time.. like now 😞virus.PNG
James.Youmatz
Autodesk Support
Autodesk Support
Hi @JHRendon ,
Email me at james.youmatz@autodesk.com and we can set something up. Also, are you on a home internet network?
James Youmatz
Hi James,
I got exactly the same error although I am not using a proxy server.
I am on my home internet network.
Do you still know how you fixed it the last time?
Thanks for helping.
Janik
I'm am getting the same issue, no proxy server on, no firewall, I'm login in as admin
I even tried this method
 C:\Users\Home\AppData>"Fusion 360 Client Downloader.exe" -o single
I still get Winerror 10061
daniel.bartenschlager3KT8U
Observer
Observer
The same at my system. No proxy, every port and application allowed in firewall but still Winerror 10061...
