Announcements
Will F360 bog down with too many details?
William_Dec_45
William_Dec_45
I'm currently designing a part with hundreds of iterations of a square .125" x .125" with .02" separating the squares on all four sides. The more squares I draw, the slower F360 gets. I tried saving and then restarting the program to clear the auto-saving load. It didn't change anything. Would I be correct that any one drawing can only have so much detail? Thank you for your time.
jeff_strater
are you doing these iterations in a sketch?  If so, then, yes, hundreds of sketch rectangles, especially if it is in a sketch pattern, will be intolerable.  Do your patterning at the solid body level instead.  If you want to share your design, folks here will take a look at it and offer suggestions.
Jeff Strater
Engineering Director
g-andresen
Please share the file. Then we can give suggestions for alternative and faster methods.
File > export > save as f3d on local drive  > attach it to the next post.
günther
TheCADWhisperer
Iterations, or instances?
Do you have a picture of something similar that already exists in the real world?
William_Dec_45
I'm so sorry it took me so long to reply to your generous offers for help. I understand what a stupid technique I was using. I know better. I wasn't firing on all cylinders. I should have simply made a disk with a 1mm thickness, and then extruded the openings I needed. Just the same, it did work. I was making a mesh to go inside a flange that mounts atop my beehive. Once mounted, jars of sugar water get plugged into the flange. Pictures attached. Thanks for all your help.
William_Dec_45
I don't see anywhere to 'accept solutions' and put this to bed. But... I do. Thanks, guys.
