Fusion Support
Why share link shows assembly partialy dissmandled when viewed in browser..???
2 REPLIES 2
giota_nikola
115 Views, 2 Replies
Can someone please explain this result when sharing a legitimate link to a browser..?
 from the above..
to this..
 all attempts to find problem failed ..
..eminent presentation of product to client about to fail..
2 REPLIES 2
jhackney1972
in reply to: giota_nikola
Could it be that your Assembly Joints are not complete?  Hard to tell unless you share the model.  Open in Fusion 360, select the File menu, then Export and save to your hard drive.  Attach to a reply post using the attachment section.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
giota_nikola
Thank you for your reply!
i tried rolling back versions, doing undo's to check when may something have happened, but to no avail.
everything was fine one day and the next day it was like this...
other designs show ok.
maybe a bit quantum fliped somewhere ..(
