Fusion Support
why is this happening ?
4 REPLIES 4
mreynoldsTPVRE
209 Views, 4 Replies
So making the model I'm working on and it's tilted, ??  not sure how, or how to fix it. thank you.
Tags (1)
Labels (1)
4 REPLIES 4
@mreynoldsTPVRE
Did you intend for this to be 3 different bodies at this stage?
with interference between the bodies?
or did you intend to Join?
Is your Sketch3 fully defined?
Did you intend to Cut circles through the part?
Try resetting the view cube (Reset Front).
Mark Hughes
Owner, Hughes Tooling
No, but I need bodies 4 an 5 to be 1 inch when joined to body 3 making thickness in them areas 1.5".
I'm not sure, I learned on SW.
Did you intend to Cut circles through the part? No, I need tap holes .75" and 1.25" deep.
 Thank you.
CSWP here since 2007.
Apparently you didn’t have a very good instructor - there is no difference between SolidWorks and Fusion 360.
