As you can see I have a dimension that is 0.002", but as soon as I press return it shows a value of 0. In my Preferences I have General precision set to 0.1234, so I can't figure out why it is still showing zero.
What am I missing here?
Can't share my project file, sorry, working on proprietary IP over here.
Solved by glencandle. Go to Solution.
Just a guess, if the General Precision was at 0 when the dimension was initially placed and then your changed your General Precision to 0.1234, the dimension will not updated until it is deleted and replaced.
John Hackney, Retired
I experienced this behavior once.
After I had increased the number and then reduced it again it was no longer reproducible.
Everything was fine in a new file too.
I will keep an eye on it
günther
@glencandle wrote:Can't share my project file, sorry, working on proprietary IP over here.
Can you reproduce this issue in a new dummy file that doesn't have any proprietary IP?
Or does the issue only occur in this one file?
What if you save the file with a new name and then delete all geometry.
Create a simple rectangle. Does the issue persist?
Thanks for your responses. I fixed it, though I do believe it was a software glitch. I had "Foot and inch display format" set to "Fractional" and I guess because the size was 0.002" it just rounded the down to zero rather than show 1/500". I'm not sure who would want that, but there it is.
Interesting note: I changed the setting to Decimal and my original value appeared. Then when I changed it back to Fractional, strangely, it continued to display as 0.002" (instead of the original 0), though all of my other values are correctly being displayed as fractional. I don't know, seems to have a mind of its own, but either way I'm off and running.
