Announcements
Why has "save as stl" changed to "save as mesh"?
ian
Community Visitor
ian
Community Visitor
Community Visitor
The right click menu on the tree, used to give me an option to save as STL
why has this changed?
Rushikesh.kadam
@ian "Save as STL" option is renamed as "Save as Mesh". From this dialog, you can specify the format in which you want to save.
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
g-andresen
just watch this INFO about 3mf
günther
RChritz
Were you not going to tell us? I was just using the save as STL feature yesterday.
g-andresen
1. you can still save it as STL
2. additionally there is the option for saving as 3MF
3. both are combined under "Save as Mesh"
@Rushikesh.kadam had already pointed this out.
günther
AfterI save to Mesh, the drop down on the right of screen shows the format "STL" but the command is not live??
Rushikesh.kadam
@Anonymous the 'Format' option is grayed out if 'Send to 3D Print Utility is checked.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
