Hi I'm trying to fillet this edge but it doesn't seem to work. Any ideas?
You need to attach your model for the forum users to try and give you a good answer.
John Hackney, Retired
A fillet between flange and pipe requires that the parts together form a combined body.
günther
Ok here it is.
@g-andresen gave you the answer and you have only one body but a section analysis will show you the issue. You flange extrusions on each end only have edge contact and Fusion 360 does not see that as a solid body. Model is attached with one end fixed.
Ok thanks you both. Im new to Fusion and still trying to learn the basics.
Please pick the Accept Solution for both of us to close your forum question.
