Fusion Support
Why does view keep changing to Orthographic?
13 REPLIES 13
Message 1 of 14
zmihlrad
943 Views, 13 Replies
Morning all,
Trying to figure out how to get my view to always be perspective with ortho faces. It CONSTANTLY reverts to orthographic which I don't even understand the purpose of because that view is always oddly skewed to look at.
13 REPLIES 13
Message 2 of 14
ryan.bales
in reply to: zmihlrad
Its a regression in the update - I logged it yesterday with the team.
https://forums.autodesk.com/t5/fusion-360-support/ortho-problem-after-update/m-p/8974748/highlight/t...
If you disable Auto-look at Sketch it seems to not do it (in as much as i've seen)
Ryan Bales
Fusion 360 Product Support
Message 3 of 14
daveG32QF
in reply to: ryan.bales
Any further news on this as it's still doing it?
Message 4 of 14
ryan.bales
in reply to: daveG32QF
Last i tested and was aware it was slated as fixed for October release.
Ryan Bales
Message 5 of 14
bonobox
i still have this issue in 2020
any suggestion?
Message 6 of 14
ryan.bales
in reply to: bonobox
I doubt its the exact same issue as that one was specif to auto-look at sketch, i just tested the issue from above and its still fixed.
What are your repro steps?
Ryan Bales
Message 7 of 14
to3dornottobe
When you simple edit a sketch previously made in a more complex drawing and close the sketch the issue is still present till today in some drawings/objects.. If you open another drawing and do the same, the problem is gone and it also solves the issue in the drawing you initially had the issue in. So in other words, it's hard to reproduce, but still very present.
Message 8 of 14
joeltavares78
I have the same problem as to3dornottobe.
When working on more complex projects and when I edit a sketch that is a few steps back on the timeline, the perspective changes back to orthographic after i finish the sketch.
Message 9 of 14
I'm having the same issue as well.
In my case, I believe the Camera setting goes back you Ortho when I use the Look-At command to look at a sketch on a plane that is not in the 3 origin planes.
Message 10 of 14
alexlegion
June 2023. The problem is still in place.
Fusion 360 periodiaclly arbitrarily without any reason switches Prespctive Camera to Orthographic.
Message 11 of 14
lucian.noel7
I am also encountering this problem. It keeps happening since 2020, when I've started with Fusion 360 and never stopped. I haven't tried disabeling the "Look at sketch" mode, but it  would be nice if it worked well anyway, in any mode.
Regards
Message 12 of 14
levelup10k
 November 2023
  The problem is still there. Do you think this is going to be resolved any time soon?
Message 13 of 14
alan.jonesXHXUF
Still there now in 2024...
Message 14 of 14
I’ve had this issue for months. Very annoying.
