Announcements
Why cant I create flat pattern?
emanolinno
emanolinno
I need to create a flat pattern of this model so I can optimize the materials for shear cutting.
I've created a similar model with the same steps before but this time it doesn't work.
Started by creating offset sketches for each end. Then Surface Lofting, thickened and Converted to sheet Metal.
I tried to Unfold too but an error window pops saying it's caused by a model error.Captura de Pantalla 2021-06-28 a la(s) 13.53.58.png
TheCADWhisperer
Sides are not planar - you can test this by attempting to create a 2D sketch on the faces.
Now let me take a deeper look...
Yikes!
Sketch1 and 2 not fully defined?
Duplicated Dimensions?
Dimensions don't match?
emanolinno
I haven't notice that, I'll check that right away! thanks for the interesting feedback.
TheCADWhisperer
@emanolinno wrote:
I haven't notice that….
Kind of hard to not notice the sketches not fully defined.
Did you notice that I Attached a file with corrected geometry in my previous response?
emanolinno
I guess I need to understand how to define a sketch first! Thanks for the file  and time.
TheCADWhisperer
Blue geometry should keep you awake at night.
