Further to my initial message, admitedly this is my first time modelling using surfaces - I usually use solids but often get into trouble with complex lofts, so thought its time to learn surface modelling. I watched the very useful video on 3D sketching and surfacing found here https://www.youtube.com/watch?v=7F2SkJhI2g0 and although there are some strange steps, I thought these two simple surfaces could be joined into a solid. Im surprised that if I use the extend and trim method, then Fusion crashes. If I try to loft between the edges where I want to close the solid, I get self intersecting errors.
Is there another best practices method I should be using?
