Announcements
Why Can’t I send a 3MF file to a 3D print utility?
RubyRedRick
RubyRedRick
If I save a component or body as mesh, the dialog offers 3MF, STL (binary), and STL (ASCII).
However if I check the box “send to 3D print utility” (in my case Simplify3D) , STL (binary) is selected and cannot be changed.
This is annoying, particularly when the part is small, and Simplify3D wants to scale it in inches rather than millimeters.
serge.quiblier
Hello @RubyRedRick
Have you tried to create a setup, then select a printer.
Now you should have access to the option in the menu :
Have a pleasant day.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
RubyRedRick
I don’t understand what kind of setup? Please note that I CAN send a binary STL file to Simplify3D, and I can save a 3MF file from Fusion and import it to Simplify3D.
What I can’t do is send a 3MF file directly
serge.quiblier
Hello @RubyRedRick
Sorry i no read you post carefully.
Effectively if you select any software, except Cura, the software force an STL output.
Cura may allow a 3MF output.
I will ask a question to the developers, if it's a mistake or what is limitating?
Regards
Serge.Q
cam.autodesk.com
HughesTooling
I've not noticed auto scaling in Simplify, have you tried to uncheck the Automatic scaling in Simplify?
Mark Hughes
Owner, Hughes Tooling
