Fusion Support
why can't I have an offset of an offset?
3 REPLIES 3
sander.koorevaar.online
149 Views, 3 Replies
I have a simple question (I think). Why can't I make an offset from an offset?
Tags (1)
Labels (1)
3 REPLIES 3
It's a stupid Fusion thing. When using Offset, the geometry is auto constrained as an Offset. If you select the Offset constraint symbol and delete it, you can now offset the geometry again.
Thx
I believe it's that way in order to prevent an avalanche of recalculations should a change in one early offset kick off a recalculation for each subsequent and dependent offset. By deleting that constraint, you are breaking the parametric link so the offset does not update if the original dimension changes.
Lance Carocci
Fusion 360 QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
