Fusion Support
Why are my tokens being used?
1 REPLY 1
rprovideo
61 Views, 1 Reply
Hi
I'm mostly a free user. In the recent past, I have activated the trial (I have done it once before, but got a message I can do it again), and tried some extensions too. I wanted to see if I can do a single force calculation, so I bought 100 tokens (as that was the minimum amount).
I am back on the free mode, but recently got a message, that if I want to save a model, I have to use some tokens, or have it closed and return to a previous save. Since I did not do serious changes, and didnt wanted to go pay model, I refused and opened an older, saved version.
I just looked in my token history and found that some of the tokens were used up. Specifically, 16 in the last 15 days, on some days, looks like 2/day. I cannot figure out what is taking them, but I now have Flex in my Fusion title bar instead of Free.
I do not mind paying for some uses, but I want to know when, and for what, and I would like to stay a free user for 99% of my time.
Thank you
Balazs
1 REPLY 1
jhackney1972
in reply to: rprovideo
If you are seeing "Flex" on your Fusion 360 application I suspect that you are using a Flex Fusion 360 Contract.  I would log into your Autodesk Account and find out.  This webpage talks about using Fusion 360 on Flex.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
