Hi @karina.harper
thanks for your interest and proposal!
My actual problems began when I used Insert Derive for the first time - see here my first post. Peter found, how to cure the laboratory experiment, but so far I don´t know, whether this is beeing investigated now or what. Later I had a similar problem dimensioning symmetrical lines and found, that it´s better to dimension their distance directly, not by dimensioning a perpendicular line across the symmetry line. But this still doesn´t explain the behavior of the Slave design.
The next problem (the only one resulting in a FUS) disappeared with the new sketch machine (FUS soluted?), no need to investigate anymore.
Then there was the problem with forgotten projection sources, you might remember. I´m still not sure, what the last response really means - does this work propperly or not?
The next problem was a circular dependency suddenly having appeared in a design, where I used Insert Derive earlier. I suppose, this is still beeing investigated.
The newest problem is a sketch, which worked well 2 months ago, now it´s generating warnings. I had to re-create it from scratch, the new one works well. I assume, this is the result of some changes at the new sketch machine - OK, but the idea, that any older design might be damaged just by opening it in the new SW version is quite frightening.
Well, so far a short overview of my substantial posts. I hope, it will not depress you.
Cheers
Kristian
