Hi @Anonymous ,
According to the log, you may be using a proxy server. I guess there may be some issue in the proxy. If you are using a proxy server try to turn off the proxy and try installing fusion 360 again.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzawhat's the problem actually, i couldn't figure it out.
