Announcements
Where is move in Edit in Place?
mickhanks
mickhanks
I edited a model that was inserted into another file but it will not update the changes. So I tried to edit in place and discovered there is NO move tool, WTH
jhackney1972
If you are using the Edit in Place function, the Move is automatically eliminated.  You are leaving the assembly during this command so the Move command has no meaning.
John Hackney, Retired
jeff_strater
not all commands or options are available yet in Edit in Place.  Component Move seems to be one of those that is not yet implemented.
Jeff Strater
Engineering Director
Rushikesh.kadam
@mickhanks As I do not have access to your design not sure if the soultion will work.
There is a way you can use the move command in edit-in-place mode, by activating the local context. Can you check if it suits your requirement?
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
