When will Fusion 360 have the same bidirectional and association with AutoCAD dwg that Inventor has
bryan5
bryan5
When will Fusion 360 have the same bidirectional and association with AutoCAD dwg that Inventor has with AutoCAD dwg.
See videos labeled "Create models from AutoCAD geometry" and "Reuse inventor models inside AutoCAD"
https://www.autodesk.com/solutions/autocad-and-inventor#
I know you can open an AutoCAD dwg inside Fusion 360 to create a model and you can export a dwg from Fusion 360. What I would like to see is the bidirectional connection where if you make a change in AutoCAD it would update the Fusion 360 model.
Bryan Lagrange
P-BvanWyk
Good day @bryan5,
That would be a nice feature if you are utilizing your Fusion Team to save your AutoCAD drawings.
I don't believe there is any such link at this time.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
