When scaling model with user scale parameter, rigid joint flips orientation
To recreate the problem, load the model and then change the user parameter "Scale" to "(.00075 * 10) * 1 in" and watch the shutters on the house. At some point these flip 180 degrees about the Z axis on me. If they don't flip with the first scale change, increment the 10 in the "Scale" parameter to 11 as in "(.00075 * 11) * 1 in", then to 12, then to 13, etc. By 13 you should notice a flip in one of the window orientations. It doesn't seem to be completely predictable and sometimes it will flip back when you decrement the scale factor. Preparing this submission I did 10, 11, 12, 13, the window flipped, change the scale to 12 and the window flipped back, then incremented to 13 and it was fine, incremented to 14 and the window flipped 180 degrees again.
