I have a model body opened from (I believe) Solidworks that was in inches.
I scaled the body x 1/25.4 which provides a body that is in metric and appropriately sized.
Changing the size of a Hole that is 6.5mm diameter is incorrect. Selecting the hole and pressing Q, the radius is display correctly as 3.25mm.
Changing the hole to 6.6 diameter by changing the radius to 3.30 (.05mm larger) creates a hole that is 6.5039 diameter.
Multiplying .05 x 25.4 = 1.27 --If instead of adding .05 to the hole radius, you add 1.27 to the hole radius (3.25+1.27= 4.52 supposedly mm) the resulting hole size is 6.6 diameter.
Somewhere in the calculation the base scaling is being maintained.
Very misleading as to what is expected of the user here. Knowing the units previously scaled by is required + the knowledge of what the underlying software is doing which I'm personally unaware of.
In any case, unexpected behavior.
