Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
When printing 2D drawing from PDF export, the lines are missing.
6 REPLIES 6
627 Views, 6 Replies
Hi all, this is my first time on the forum.
This is my problem:
I realized a 2d drawing from a part with quotas and exported in PDF extension.
On monitor I can whatch the PDF correctly but when print it the lines about construction part are missing.
I can see only quotas and rows.
Can you help me?
Thank you very much and have a nice day.
6 REPLIES 6
ClintBrown3D
Hi @Anonymous
Welcome to the forum 🙂
Please can you share some additional information with us so that we can try to assist you. Please share a screencast of your workflow and maybe some screenshots so that we can try to help troubleshoot this with you.
in reply to: ClintBrown3D
Hi Clint and thanks for your reply.
I attached some images of my printed drawing like example.
You can see in the printer preview that the lines are all on the 2D drawing, but after printing are missing.
Note: in the bottom on the left you there is a "detailed view" from a part of drawing that is visible.....very strange!
Is it possible that I need to change some setup for the export lines in PDF format?
ClintBrown3D
Hi @Anonymous
Have you tried printing with the line weights turned on?
Which PDF printer are you using? Is it "Microsoft Print to PDF", or something else?
What graphics card and driver are you using?
Mmmmmm.....probably my problem is the "lineweight".
When I back home, I will try this.
For now thank you very much!!!
I'll let you know soon.
Hi Clint, in my properties the lineweights was turned on.
Probably when I saved the pdf file some day ago, the option was turned off.
Is it possible that during a new release installation this option is ON for default?
Altough, thank you for the support ;O)
ClintBrown3D
Hi @Anonymous
No problem, I'm happy to help.
The dialogue should remember your last used settings. A new version of Fusion should not change this.
