I'm not sure if this is even the right place to ask this, its my first time actually interacting with the community. I'm relatively new to the program. But I've been having this issue where i set a 10 degree construction plane, and draw my sketch on it. then when editing that sketch, none of the lines seem to ever want to stay on that plane and will move about freely. its so slight that I never even notice until I'm a bunch of steps down the line, and am having issues because of it. (I know this is my fault for not realizing that none of the shapes turned blue to show a closed profile before moving on) if I view the design from the side and zoom in super far, I can see all the different lines are actually not all level with each other. making it so that the surface i create out of it doesn't register as a flat surface to draw sketches on, and wont register any closed shapes to extrude or anything because of it.
I've been trying to find any kind of way to go back and edit the sketch to select all the lines and see if I could like snap them all to be flat on the construction plane again somehow but I haven't been able to find anything or figure anything out. I thought maybe there would be a command similar to the align feature where u can select 2 faces of separate solid bodies and make them flush with each other. does anything like that exist? or do I actually have to completely redo all of the steps I did after fixing the sketch? I noticed if all I do is adjust existing lines things will update down the line without a problem, but if I delete any of the lines I used for the patch commands and redraw them it requires me to edit all my features. which is completely understandable. I just don't see any possible way to fix all of those lines back down onto the plane that they were originally drawn on. I don't wanna have to completely redo it all. There's got to be a simple fix to this right? I feel like I'm missing something here.
Its not the end to the world if I have to redo it all again I guess but I'm curious if anyone has any ideas for how to either prevent this in the future or fix it in an easy way?
