Announcements
When I make a Sheet Metal Flat pattern, I cannot dimension the holes in the technical drawing.
nferhatoglu
nferhatoglu
Merhaba,
When I draw in sheet metal and create a flat pattern in Fusion 360, I cannot dimension the holes?
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post
günther
nferhatoglu
Here you are.
jhackney1972
This model was imported as a Base Feature, one side split, and then converted to sheet metal.  Because the holes were created in the Base Feature, Fusion 360 only sees them a ellipses so it cannot apply a diameter dimension. Create the sheet metal part in Fusion 360 completely and you will not experience this issue.
John Hackney, Retired
HughesTooling
The holes were created in the bent state so when unfolded they are not going to be round.
If you recreate this and add the holes when the part is unfolded then the holes will not be round when you refold so you need to decide in what state you need the holes to be round.
Mark
Mark Hughes
Owner, Hughes Tooling
