I have a copy of the same design. Working on the same edge the chamfer command points differently in each design. Below are pictures showing the difference. One is pointing parallel to the bore, the other is pointing perpendicular. It's the same chamfer command options, "Distance and an Angle".
What influences the initial direction of the chamfer? With Inventor, I can reference a face with the selected edge to control which way to measure the chamfer. Is there any way to control the direction of the chamfer in a similar manner? What changes the direction of the chamfer?
