WebGL context lost - generative design
s15jbeis
Message 1 of 9
s15jbeis
Hey,
Unfortunately, it is not possible for me to view my results, which were created with generative design. I get the error message: "WebGL context lost. Unable to recover from software mode..." I have an AMD Ryzen 7 8845HS processor and an integrated AMD Radeon 780M graphics card. The graphics card is not listed with the certified graphics cards in Fusion 360. Is that the problem? What can I do now?
Greetings and Thanks for your Help!
Replies (8)
Message 2 of 9
CGBenner
@s15jbeis
Hello & Welcome!
I found this document related to this error and BIM 360, but a Google search would suggest that the problem is the same in nearly every instance.  Take a look at this, and see if any of it helps.  Good luck!
Chris Benner
Message 3 of 9
henderh
Hi @s15jbeis,
If the solution above doesn't fix the issue, and you have a commercial or student account, the online version of Fusion can be used to view the outcomes in the Explore workspace: https://fusion.online.autodesk.com/
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 4 of 9
s15jbeis
Thank you very much @CGBenner for your help.
I followed the steps in the document. Unfortunately, that didn't solve my problem. Thank you very much anyway
Message 5 of 9
henderh
Hi @s15jbeis,
Could you try setting an environment variable QT_OpenGL = angle
This article has the detailed steps: Results of Simulation and Generative Design studies do not display in Fusion 360
Best regards,
Hugh Henderson
Message 6 of 9
s15jbeis
Hey, thank you very much for your help. I haven't found this solution myself before. Unfortunately, this method couldn't solve my problem either.
Message 7 of 9
CGBenner
@s15jbeis
Hello, what kind of Fusion license do you have? (Commercial, Student, Hobbyist)
Chris Benner
Message 8 of 9
270304
Community Visitor
Community Visitor
I got the same error message and have an educational license.
Message 9 of 9
s15jbeis
Hey, i got the studetn lizense. It's more of a problem with my computer. It also worked on other computers with the same license.
Thank you anyway
