Web viewer not displaying referenced models correctly
- Mute
- Permalink
- Report
I'm having a problem when I use the web viewer to share a model and with the download files it produces on a public shared link. Some subassemblies with referenced components and joints are not aligned correctly.
The picture on the left is the correct version as seen in F360. On the right is the web view. A download file in F360 format from the web link also has problems although sometimes in different places. This seems to be where there is a linked component and the component has been made rigid with a joint. However it still occurs even if the whole model is made into a rigid group.
I know I could create the same model without using referenced components or joints but this would not be the required workflow for the entire project. Also some components of a similar type are generated OK in both views and download files.
The shared link for this model is https://a360.co/2yrjQeX
