Warnings when trying to create cut lines with split body/face
I need to create some cut lines in a boat hull ive designed so it can flat patterned with exactflat and not having any success in doing so. I marked up the screenshot so ill explain what each color represents but its kinda obvious. Green Segmented lines are break lines or lines that will bent in a press break. Orange lines is just outlining the part Red lines are the cut lines Ive tried using the body next to it as the cutting tool and i also tried creating an axis through two points and then a plane on angle on the two small straight lines at transom and all instances i get computation failure or failed to compute or something very similar. Am i doing something wrong or can it not be done? thanks
