Visueal settings, Visuel themes
I am new to fusion 360, and the program is not following my windows visual settings.
I am running in High contrast mode on windcows 10 and the program is showing in normal colors.
I have searched the forum, and unable to find any of the settings for either high contrast, or dark coloeed theme.
attached is a screenshot of what I see.
lance.carocci
Hi @Anonymous, most of Fusion 360's application windows are drawn using custom UI styling rather than the Windows [or macOS] UI system, and as such are not impacted by Windows' themes.
Fusion on Windows does not yet support visually-accessible UI tweaks such as scaling, dark mode/high contrast, or colorblindness, but this is an area I am gathering feedback for. Would you mind telling me a bit more about your preferred UI, or things you are trying to change about the Fusion 360 UI? Visual examples are always appreciated!
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
@lance.carocci
I am looking to change the background and font color,  similar to how my tool tips show but darker(example of what I see attached below.  also making the font size slightly bigger or at least adjustable.
example 1
  I have few other examples but will have to take screenshots on another PC.
IF you would like more examples .
I will continue to use the program with the current settings.
   Thank you for your quick reply , and will gladly give feedback .
Well, I have this issue too.
It's a challenge to see the grey text on white backgrounnd for me annd I think I'm not alone
