Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Ciao a tutti ,
è possibile in Fusion visualizzare nella messa in tavola parti di costruzione del disegno ?
Ho allegato uno screen dove ho costruito un punto calcolato con l'intersezione tra un piano e un asse,
posso ora visualizzare il mio punto nella messa in tavola ? Ma servirà per riferimento di quotatura .
Grazie
Ciao
[translated with Google]
Hi everyone ,
Is it possible in Fusion to display construction parts of the drawing in the layout?
I have attached a screen where I constructed a point calculated with the intersection between a plane and an axis,
Can I now view my point in the table setting? But it will serve as a dimensioning reference.
Thank you
HI
Solved by g-andresen. Go to Solution.
The point cannot be used directly for dimensioning in drawings.
However, it can be used as the basis for a point in a drawing.
The corresponding sketch (design) must then be activated in the drawing.
günther
