Visual Style switches back and forth repeatedly with no user input
Hi folks,
I often use the default hotkeys to switch between Visual Styles (Ctrl+4 through 7 primarily), but have noticed more and more lately that my selection will continue to flip-flop back and forth to what it was previously set to. Sometimes it seems to be on a timer -- after 5 seconds or so, it will switch from Shaded With Visible Edges Only to Shaded With Hidden Edges (or whatever). Other times it seems to react to movement -- the moment I reorient the model, it will swap back to the previous setting.
It also does not reliably update the Visual Style in the menu, as seen here. I had switched from Hidden Edges to Visible Edges Only, only for it to flip back to Hidden Edges, but the menu still showed that it should have been on Visible Edges Only.
