Fusion Support
View cube disappears
1 REPLY 1
lbatemanBUCM5
75 Views, 1 Reply
The view cube disappears mid way through working in design. The only way I can get it back is to restart fusion.
fusion version- 2.0.20981
macos-15.2
1 REPLY 1
Hi @lbatemanBUCM5
  • Toggle ViewCube Visibility: Use the shortcut Shift + Command + C to toggle the ViewCube on and off. Sometimes, it refreshes the UI.
  • Graphics Driver Issues: Check if your Mac's graphics drivers are updated or compatible. Fusion 360 can struggle with outdated drivers.
  • Reset Preferences: In Fusion 360, go to Help > Reset Fusion 360 Settings to revert to default settings. It might resolve any hidden UI issues.
  • Disable Hardware Acceleration: In Preferences > General > Graphics, turn off Hardware Acceleration. This reduces strain on your GPU and can fix visual bugs.
  • Reinstall Fusion 360: If none of the above work, uninstall and reinstall the software to resolve potential corruption.
Just a few suggestions that were once suggested to me in the past with this issue, hope it helps!
Happy New Year Regards!
Ricky:rolling_on_the_floor_laughing:
Has this started since the latest update or is this an issue that you've had for a while?
