Fusion Support
View Cube Axes Not Correct. Please Help
4 REPLIES 4
LNColorado
204 Views, 4 Replies
My view cube currently has the Z axis to the left of the "Front" of the view cube.
I would like to have it look like this. With the Z axis in the back
4 REPLIES 4
Set as desired orientation.
Right click on the View Cube and select Set as Top.
You can set the default in your Preferences.
LNColorado
in reply to: LNColorado
Thanks! Is there anyway I could have a visual step by step representation?
Thanks! I figured it out. How would I set it as my default in preferences?
@LNColorado Click on image below to enlarge the view.
