Ok, I could not use "create a copy" and then link to that for whatever reason so I had to export them as step, then import back. Joints disappeared so I just made a rigid group.
Here is the link: https://a360.co/39CGI1p
I definitely know that measure is 3D, the point of the sketch was to compare in the X axis only, not in Z (the sketch moved everything to the same Z plane).
The model is a 4th axis tombstone, the black parts are being machined. I am making the pocket for them to sit in, but started to question whether or not the parts (black clamp parts) are square (aligned?) to each other despite them being positioned by joints (tried all different joint origins and types and I get the same result). They should be in the same Z plane (which they are), but their alignment in X is confusing due to the results of the measure tool.
So when you compare two vertices (in green circles) on the two clamp blocks together they show they are not aligned in X (left and right, in red).
BUT when you compare those two vertices individually to the same corner of the tombstone they show that they are aligned in X (left and right).
I get strange results depending on which point I pick first. The screenshots above are with selecting the corner of the tombstone first.
I hope the point I am trying to make is clear here, One way of measuring shows the two blocks are not aligned in X, and the other method says they are. The tombstone is also verified to be aligned with the origin (so the X sides of the parts are in line with the X axis of the origin).
Peter.
